Jd crawler40
Jd crawler40
Got this 40, was working really good until one day started to backfire out the carberator air intake. Timing check, carb check, everything looks ok, any advise on what could be wrong. Thanks
- DukeofDeere
- rustywheel
- 40C crawler
- Contact:
40c backfire
My 40c did exactly the same thing and what I found was that the pivot pin on points was sticking and some times points wouldnt operate and when they did it would backfire, this was an intermittent problem not continuous
- gregjo1948
Check valve timing and, as boler76 suggested, check the points for proper operation and also check the distributor bushing for excess wear causing the point gap to be erratic. gregjo1948
Users browsing this forum: Google Adsense [Bot] and 28 guests
