450 power steering?
lti
450 power steering?
Post by lti » Mon Aug 31, 2015 9:50 pm
Anyone have much experience with the pump that mounts on front of engine to the block. thanks
tjdub
Post by tjdub » Wed Sep 16, 2015 9:18 am
I've had mine off to put a new seal in it. Found out the shaft was too worn so the new seal still leaked. I was going to take it out again and drive a Speedi-Sleeve on the shaft, but that keeps moving down the TODO list.
What do you want to know about it?
Post by Tigerhaze » Wed Sep 16, 2015 11:07 am
FYI as discussed in other threads the "seal" on those pump shafts is really a dust seal so putting in a new seal on a worn leaking pump will not stop the leak under pressure. They are basically "throw away" pumps when worn.
Users browsing this forum: No registered users and 40 guests
