td14addict
- 40C crawler
Post
by td14addict » Mon Aug 17, 2015 6:47 pm
I am wondering what tricks you folks have come up with for removing the outer race on the upper final drive bearing. I have the one out of the final drive housing. I am just looking for suggestions on the other one before I try it myself. We were thinking heating the outside and seeing if it will drop out.
Here's a picture for reference.
Thanks!
1956 420C, 1941 International TD14
notmeu
Post
by notmeu » Mon Aug 17, 2015 7:04 pm
Mikeym70
- 430 crawler
Post
by Mikeym70 » Mon Aug 17, 2015 7:12 pm
Yep - slide hammer kit will do the trick.
Typically a local parts store(advance, autozone, etc) will "loan" these types of tool kits out. I made several trips to my local parts store to utilize the service and keep costs in line.
1010 gas crawler 6 way blade. New to me 3/2015.
vailvalley59
- 430 crawler
Post
by vailvalley59 » Mon Aug 17, 2015 7:13 pm
You can run a hot bead around the inside with an arc welder and the bearing will fall out--no fuss no muss.
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
td14addict
- 40C crawler
Post
by td14addict » Mon Aug 17, 2015 7:16 pm
I guess I will be making an end for my slide hammer tomorrow. There's not much local for those types of kits but I do have a slide hammer and am not scared to fab something up.
Thanks!
td14addict
- 40C crawler
Post
by td14addict » Mon Aug 17, 2015 7:18 pm
just seen the welder post, sounds like a good idea, ill give that a try first!
- Site Admin
Post
by Lavoy » Mon Aug 17, 2015 8:32 pm
Welder works great, but I have a internal bearing puller as well.
Owner and moderator
www.jdcrawlers.com
whiteclipse16
Post
by whiteclipse16 » Tue Aug 18, 2015 5:55 am
I 3rd the welding trick. Worked great on mine.
Ben
td14addict
- 40C crawler
Post
by td14addict » Tue Aug 18, 2015 9:23 am
Tried the welder this morning. In about 5 minutes both bearingsides were out! Thanks for the tips!
GaCatskinner
- 420 crawler
Post
by GaCatskinner » Fri Sep 04, 2015 5:31 am
The welder trick saved my tail when I was working on an old Case hay rake. It amazed me how easy the old race just fell out.
