MC dozer blade part identification help
td14addict
Post by td14addict » Fri Aug 14, 2015 8:36 pm
I went to the fellows house that had bought our 420C from us 24 years ago and asked him if he would sell the remaining parts he had for the crawlers, he told me anything in the yard i wanted I could have. So I left with a full car load of old parts for free. Among them was this piece, which sports green and yellow paint so I assumed it was off something JD.
After a lot of searching I have finally located where the part is used, however I have no clue what its purpose actually is. The only assumption I had was that it either stopped the blade from rising any higher (which I am not sure why you would want) or it was an early attempt at some sort of "Down Pressure" Does anyone know what the function of this piece on the Lift Cylinder is? I have only seen it on these 2 MC machines pictured here.
If it is by some chance a rare piece that someone needs to finish there machine I would be more then happy to work something out.
gregjo1948
Post by gregjo1948 » Sat Aug 15, 2015 4:51 am
Perhaps it's adjusted to maintain a set depth of material being graded. gregjo1948
cdunn
Post by cdunn » Sat Aug 15, 2015 3:15 pm
Those cylinders are/were used not only on blade but remotely on pull behind attachments of different sorts ie. harrows ect. where limiting stroke of cylinder is necessary.
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sat Aug 15, 2015 6:44 pm
Just below were the cylinder rod attaches to the lift on the blade there it a a piece of flat bar that when the blade is up you flip that over and it will hold the blade up so the cylinder can be removed and used on the tow behind attachments that require hydraulic lift.
I believe these cylinders with adjustable stroke were used on the wheeled tractors also.
nothing crawles like a deere
td14addict
Post by td14addict » Sat Aug 15, 2015 8:13 pm
Cool! thanks for the info. that makes sense now. I have found a number of pictures of them now that I know what to look for.
Post by Stan Disbrow » Sun Aug 16, 2015 5:32 am
In the first pic, short hoses were used so it can't be used as originally intended. The second pic has the long hoses from the rear and on top of the fender to the blade, as it should be.
Most MCs had no blade, and were used just with pulled equipment. Some had the toolbar, which was outside mount and usually was attached toward the rear. There were many tools for it at the time which made for a nice setup. The toolbar could be detached and the machine turned around so it was on the front. There was a blade tool for it as well.
Later on the 60 blade came out which is inside mount and just stays on the machine. And the multi-use cylinder winds up used for that as well. Hence the hold-up bar.
Users browsing this forum: No registered users and 179 guests
