1010c crawler distributor timing
Best way to set the distributor on this crawler. Its back fires though the carb. Help please
- gregjo1948
Have you checked the compression? You may have a valve problem. Set the points, loosen the distributor, point the timing light at the mark on the crank pulley or flywheel and twist the distributor. If you have a manual,it will give you the point gap and where the timing marks are located. gregjo1948
- gregjo1948
- gregjo1948
If you had the head done, valves shouldn't be a problem. The back fire thru the carb may be the wrong plug wiring sequence. Sounds like it's sparking with an open intake valve. Not sure on sequence, but I'm thinking, 1342. gregjo1948
- gregjo1948
Lack of compression is why it's not running for sure. The next question is, why the poor compression? If your firing thru the carb, , it's probably not a compression issue. Check valve timing and valve clearance. gregjo1948
Users browsing this forum: No registered users and 335 guests
