I have my JD manual and it is clear as mud,
I am adjusting my new steering clutch and brakes.
the manual says to set he levers out at 2" and adjust the clutch adjusting rod to remove all free travel, does that mean to set the throw out bearing at touch point of the steering clutch pressure plate fingers?, if so, then I loose all my "range of travel" to engage the steering clutch before I start moving the brake band. if I follow the poorly written direction I barely engage the throwout bearing which barely dis-engages the steering clutch.
any suggestions?
adjusting steering clutch and brake
450 dozer
