Starting to look at all the 'enjoyable" projects on the 420c not sure where to start but could use some advice on the following. Fortunately engine runs well and everything is functional
1) only 3 of the 8 lower rollers appear Ok . others are bad to shot-- are rebuild kits available for the rollers?
2) Over half of the pad bolts are very loose. Can I just remove (cut off) old bolts and replace?
3) While track tension seems ok, I have 30 links in each belt and assume one was removed. Is this an issue? Can I add a link and get new pins/bushings?
Thanks in advance. More questions to come. This is a keeper - want to ultimately give it to my sons to enjoy for another 50 years.
many opportunities(needs) "new" 420c
420 c
First the bottom rollers.No rebuild kit as such.Seals alone will be over
$100 dollars for the pair.Roller used are available but can be iffy to obtain better than what you have.Shafts,and bushings for the roller are available from Deere but you need deep pockets.Lubed for life rollers from a JD 350 are a bolt on replacement.Deere has them and Lavoy may still have some.Last I got from Deere were $125.00 ea.
Thirty pads suggest the smaller front idler and the machine should have 31.The machine has been short tracked to get more hours out of worn out pins and bushings.If you get the tracks repinned and bushed you will
need a replacement link for each side.Getting pins and bushing is spotty at best and then you need someone to install them.Lavoy may be able to help you with the parts and work but you will have to get them to him.
If you want the machine to last another fifty years be prepared spend
way more than you ever hope to recover at resale.Thes old girls are fun
to use but can be a huge money pit.Luck,JimAnderson
- Paul Buhler
I've been getting mine in shape for a few years now, and It has paid me back nicely. Of course just about the time I think we are even, my 420 tells me differently. Good luck with your new machine and the decisions you make.you will be spending several grand before you know it but what the hey, ya cant take it with you... Very Happy
Users browsing this forum: No registered users and 314 guests
