Voltage Regulator
Voltage Regulator
I think my Motorola voltage regulator has died. I have read several articles about converting to a 1 wire alt but what about just using a run of the mill voltage regulator?
I think the motorola one is about 150 bucks and a car one is less than 20 bucks. They have the same hook up field, stator, etc....
Any thoughts?
Any thoughts?
JD- 450C track loader
Serial #208336T
Serial #208336T
I would have to assume that the regulator is specific to the alternator it is running, so I tend to doubt that the "car" one would work, but who knows.
A regulator has to be designed to match the impedance of the alternator field coil. If not, then it can easily not produce enough power, or, worse, produce too much. Go too far in the too much direction and everything burns out.
So, you can try the low cost option, and pay attention to the voltage produced with a meter and also how hot the regulator and alternator become. If the voltage is ok, and things don't overheat, you should be ok. If it starts going wrong, then the backup plan would be to buy the proper regulator.
these may be what you need at least they crossed for me http://www.ebay.com/itm/Voltage-Regulat ... c5&vxp=mtr and http://www.aspwholesale.com/index.php?_ ... ct_id=2009
Re: Voltage Regulator
Where is the voltage regulator located on a 1969 JD 350 dozer, I have looked all over and cant find what I see in pictures for the R2J1 voltage regulator, it has 4 wires according to replacement parts pictures. What I find that might be it has 6 wires. Could I possibly need a RS2J1 voltage regulator ?
serial number 109011T
