No grease fittings on 350B lower rollers. How to lubricate?
What do I do to lubricate lower rollers on a 350 B Crawler when there are no fittings on the rollers/pins? All that is there are centers on the shaft. No threaded anything anywere.
They might be lifetime sealed replacement rollers- if so then no lubrication required. However you should make sure that is the case.
