450B final drive oil?
jakebrey
Post by jakebrey » Tue May 26, 2015 9:29 am
Are the final drives oil separate from the transmission oil? If it is can anyone tell me where I check, fill, drain and what type of oil it takes? Thanks
1971 JD450B 6 way blade & ripper
Post by jtrichard » Tue May 26, 2015 10:38 am
IF it is a "B" then yes it is separate and it takes same as fluid as the trans
jakebrey
Post by jakebrey » Tue May 26, 2015 11:33 am
ok thanks. Does it have a fill plug and a check level plug like a rear end then?
Post by jtrichard » Tue May 26, 2015 2:55 pm
here is a post that may help CHECK and see just what lube is in it before you add any some 450s still used 90 wt it looks like http://www.jdcrawlers.com/messageboard/ ... =450+final
