Need some adult guidance!
Had the '68 350 out the other day skidding some logs on the property when I noticed that the engine was not decreasing RPM immediately when I moved the throttle lever to idle position. The RPM revs up without issue but it may take 15 seconds for the engine to come down to idle once I cut the throttle. No miss or any other noticeable issues. New lift pump and complete filter change 10 hrs ago. Throttle linkage seems to be operating normally, bell crank on pump isn't sticking. No engine miss or loss of power just takes a while to idle down. Any one else have this happen?
350 slow to idle
Users browsing this forum: No registered users and 122 guests
