450B trans temp.
450B trans temp.
Hello, Does anyone know what is the normal temperature of the trans. should be? I replaced the broken temp. gauge with a oil temp. gauge that reads 0 to 250. It is running around 215 degrees. My manual does not give a temperature range in which it should run. Thanks!
That would be a good temperature for cooking any water out of the system, Not sure I would worry if it doesn't get much hotter.
Trans temp
I have a 450C replaced the electric with a mechanical no degrees on it but the needle stays in the lower section yours seems hot to me .
JIM
JIM
Users browsing this forum: No registered users and 253 guests
