I HAVE A FORD A62 WHEEL LOADER WITH A 256TD MOTOR WITH A MINIMEC
FUEL INJECTION PUMP....IF I LET THE MACHINE SIT FOR A DAY OR SO, I HAVE TO RE-BLEED THE INJECTORS....CHECKED ALL INCOMING HOSES AND LINES.....THOUGHT CHECK-VALVE MAY BE THE ISSUE...REPLACED THE CHECK-VALVE.....STILL THE SAME ISSUE.......NO EXCESS FUEL IN PUMP OR CRANKCASE..............RACK MOVES FINE AND EXCESS FUEL BUTTON MOVES RACK OVER LIKE IT SHOULD........ANY INPUT WOULD BE GREAT.
FUEL INJECTION PUMP QUESTION FOR J. DEMARIS OR ANYBODY ELSE
- vailvalley59
- 430 crawler
I had a similar problem with a diesel car that I owned--got hold of a spray can of a white chalk and coated the fittings that went to the injectors--found a small leak that was not visible--tightened up connection and the problem was solved.. It acted as you said--would start fine if you ran it everyday--but would not start if it sat for several days. This was a Roosamaster type pump--your might not be the same type.
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
UPDATE ON INJECTION PUMP
FOUND THAT THE PISTIONS IN EACH OF THE 4 SMALL PUMPS INSIDE PUMP WERE WORE AND NEEDED A REBUILD
Users browsing this forum: No registered users and 67 guests
