Need help! No start JD350 dozer
Jb800
Post by Jb800 » Mon Apr 13, 2015 5:43 am
I have an older JD350 dozer that I havent started in a a few years. Today I wanted to try and start it so I put new batteries in it and fill diesel. It cranks but wouldnt start. We pumped the fuel pump and bled out any air we can. We got fuel up to the injector pump going in but nothing coming out to the injectors. If I spray a lil starter fluid into the intake it will fire up but then stall out. Any other suggestions on what to do from here? Bad injector pump? Thanks
Post by Tigerhaze » Mon Apr 13, 2015 9:33 am
There are a lot of threads discussing this type of issue if you search (and I would recommend you do so), but there are the main issues that tend to pop up with a fuel to pump but not injectors issue (not in any particular order):
1) Injection pump to tank return line and/or vent clogged
2) Stuck injection pump metering valve
3) Destroyed governor weight retainer pellethane ring (search for "mouse turds" in archived threads)
Use this thread as a starting point- even though for a 450 the issues are similar. The big difference in diagnosing and working on injection pump issues is not whether a 350 or 450 but whether a "C" or "D" pump.
http://www.jdcrawlers.com/messageboard/ ... pellethane
egeor
350 no start
Post by egeor » Sat Apr 18, 2015 4:37 pm
If you have not found the starting problem by now . the first place I look is the wire going to the injection pump for the fuel solenoid turn the key on and pull the wire off check for voltage no voltage no fuel.
68 350 loader
79 350c loader
88 case 580k 4x4
89 ford 2120 4x4
DrLoch
Post by DrLoch » Sun Apr 19, 2015 6:03 am
I never saw another post stating that he got it running or not. My guess is he did and just forgot about us :(
A picture would help to determine which pump you have.
450C Track Loader
291457T
Post by Stan Disbrow » Sun Apr 19, 2015 6:55 am
My old 350 was all-mechanical fuel control. One day, it wouldn't start. Because I forgot to lift the throttle lever. Everything else was elelctric fuel cut-off. I flattened the battery before I had the 'Oh! Moment of Remembrence'...... :P
Users browsing this forum: No registered users and 260 guests
