420 running issues, spark, battery, points?
Post by Stan Disbrow » Sat Feb 15, 2014 11:30 am
gregjo1948 wrote:Hey Stan--If you're adding a velocity stack, you might as well install racing slicks! :lol: gregjo1948
I saw a 420c with the rubber blocks on the pads doing a tractor pull. Off one of the recent Yoo Toob links, I think. So, for a crawler I think those are slicks! :P
original possum
Post by original possum » Sat Feb 15, 2014 3:15 pm
Lavoy is right again! Turns out the 40C was burned and rewired by my electrical engineer brother while I was away in the Army. He added the resistor to save the points, but when I changed the coil it had to go. And he used all red wire.
Post by Stan Disbrow » Sat Feb 15, 2014 5:13 pm
Ah ha! All red wire is fine, if you use Brady wire marking tags on them all to figure out which go where.... ;)
As far as electrical engineering goes, they skipped Ignition Systems 101 when I was learning it. I got my schooling in that field way earlier. :)
Post by Paul Buhler » Sat Feb 15, 2014 5:34 pm
Me too. -- "Hold that plug near the hole while I crank the engine over. Let's see if there's any spark"; no rag, no glove, no joy.
:shock:
gregjo1948
Post by gregjo1948 » Mon Feb 17, 2014 6:28 am
Paul-- There might be a little humor in the plug holding, if you're not the holder. :) gregjo1948
Users browsing this forum: Hurlbutt and 200 guests
