Snow Dozing
Post by Lavoy » Thu Feb 06, 2014 7:26 pm
You mean you have copper line now, or thinking of replacing it? Factory line is copper plated steel. I have never had any trouble cracking the brass adapters, but not hard to replace. Check your bypass pressure to make sure it is in spec just in case.
gus
Post by gus » Fri Feb 07, 2014 12:00 pm
Got a foot in the last 2 days... time to PLAY!! :lol: :lol:
gus
Post by gus » Fri Feb 07, 2014 3:00 pm
Had some fun!
DukeofDeere
Post by DukeofDeere » Fri Feb 07, 2014 5:10 pm
Looks like fun!
Duke
gus
Post by gus » Fri Feb 07, 2014 8:23 pm
Weather man says I'm going to get to play again and again and again for the next week or so :shock: :shock: :D :D :D
Post by Lavoy » Fri Feb 07, 2014 11:08 pm
Man, you guys are pissing me off, send it here. Maybe a chance for a few inches here next week, that is it. To find enough snow to push with a crawler, I would have to go down in the ditch to even find a foot of snow if that. :(
DukeofDeere
Post by DukeofDeere » Sat Feb 08, 2014 5:21 am
Trying to upload a photo here.
Duke Image
jthornton
Post by jthornton » Sat Feb 08, 2014 5:49 am
I right click on your image and select "copy image location" then paste it in the message. I select the image url and press the Img button. It doesn't like an image with a html tag at the end.
JT
DukeofDeere
Post by DukeofDeere » Sat Feb 08, 2014 8:00 am
I'm trying to do this from a "smart phone" :shock:
Haven't had a computer in a long while.
Thanks for the help!
Duke
gregjo1948
Post by gregjo1948 » Sat Feb 08, 2014 8:20 am
You need Paul Buler for a pile of snow like that. I believe he has done work at a ski resort up there in Vermont. :lol: gregjo1948
DukeofDeere
Post by DukeofDeere » Sat Feb 08, 2014 8:24 am
Haven't seen snow like this in years!
No relief in sight unless Lake Michigan freezes over!
The heated cab sure is nice!
Lavoy send some trucks and I will load them for you :D
Duke
DukeofDeere
Post by DukeofDeere » Sat Feb 08, 2014 1:03 pm
Lavoy wrote:You mean you have copper line now, or thinking of replacing it? Factory line is copper plated steel. I have never had any trouble cracking the brass adapters, but not hard to replace. Check your bypass pressure to make sure it is in spec just in case.
Hoping a single flare works...
Refused to even start the first flare :evil:
Yes is a copper coated steel line.
Duke
north country dozer
Post by north country dozer » Sat Feb 08, 2014 2:16 pm
I live on the eastern end of lake Ontario and I plow snow with my Deere 450 dozer. They do a great job. As long as ground is frozen its nice and clean. Been frozen ground since November here with quite a few 2+ foot storms that have come through. Thanks for sharing the pics... they sure do make snow removal fun!
Post by Lavoy » Sat Feb 08, 2014 6:54 pm
I think the nut is available, or I may have one. I think I can get new lines made, I do finally have a pattern, just never got around to getting them make. I thought they are a flange fitting, not a double flare.
Might be simpler to just bring the crawler there, I could have some fun on that pile.
hydrogeo
Post by hydrogeo » Mon Feb 10, 2014 8:58 am
Got started on firewood for next year and twitched out a couple of blowdowns over the weekend. My boy actually prefers the 40c over the snowmobile:
Users browsing this forum: yellowcrawler and 8 guests
