My 420C. Kind of an interesting story.
Top Gun
Post by Top Gun » Mon Jun 07, 2010 8:19 pm
Right side final drive disassembled.
Axle shaft and bull gear were in good shape to my surprise. Im going to replace all the bearings & seals in both units to be sure all is good.
I'm a rookie with steering clutches, were these bad? :lol:
Post by JD440ICD2006 » Mon Jun 07, 2010 8:22 pm
I have met a few "sellers" that would call that "slight hairline cracks but nothing to worry about, they ALL do that." :roll:
Top Gun
Post by Top Gun » Mon Jun 07, 2010 8:28 pm
After I bead blasted all the usable parts in the steering clutches I decided to paint the yellow stripe on the hood and front nose. Only took about 10 minutes to pull the nosepiece back off.
I covered the crawler with old blankets & bedspreads and bead blasted the right side track frame. (What a mess in my garage)
After I swept & ran a shop vac for 3 hours I painted the lower track frame yellow.
Cell phone pics don't pick up the real colors very well. I also hand painted the square stock that it all mounts too green afterward with a 1/8" paint brush. What a pain in the a$$.
Lu47Dan
Post by Lu47Dan » Tue Jun 08, 2010 8:23 am
According to the SM compression ratio is 7 to 1 in gasoline engine.
Nice work .
Dan.
1956 420C with GSC blade
MADJACK
Post by MADJACK » Wed Jun 09, 2010 1:43 pm
Great stuff! 8)
Post by Paul Buhler » Wed Jun 09, 2010 4:33 pm
We can almost hear it running. When you get it to that point, how about a YouTube or equivalent film clip? Thanks again for sharing your project - I know mine didn't get the total love and attention your's is getting, and it occasionally reminds me. :wink:
H-D
Post by H-D » Wed Jun 09, 2010 4:56 pm
Regarding your painting with a small brush, have you tried using aluminum foil for a masking medium? I've found applications where it is a really useful method & a time saver as well.
Top Gun
Post by Top Gun » Thu Jun 10, 2010 7:12 pm
I was contemplating replacing these bolts. Instead I bought a 1" die and chased the threads. had to cut the old nuts off as they were very stubborn. Threads are all fixed and have 25 new nuts now. (spares are alwats good. LOL!!! )
This tie-bar? was missing when I acquired the crawler and threaded rod was in it's place co I made a new piece. Not the right way but I'm hoping it works for me.
Top Gun
Post by Top Gun » Thu Jun 10, 2010 7:15 pm
Some dummy (me) thought he could fix this worn shaft. Im in need of a used one.
Also a used endcap for the roller please.
KenP
Post by KenP » Fri Jun 11, 2010 4:09 am
deleted
Top Gun
Post by Top Gun » Tue Jun 15, 2010 7:21 pm
Did some shopping with Lavoy.
2 new steering pressure plates
All new fiber & steel disks
2 new brake bands
2 new throw-out bearings
New bearings, seal & gaskets for both final drives
2 new brake rods with end links and pins
2 new brake rod boots
New pipe & muffler
2 new master pins for the track
New oil cap that I'm converting for the hydraulic tank
All new springs for release bearings and brake return
New battery hold down bracket
I think I covered it all?
Anyways, the guy was great to deal with. Even answered my phone calls and answered my "dumb" questions. :lol:
Top Gun
Post by Top Gun » Tue Jun 15, 2010 7:24 pm
Got the lower blade frame on over the weekend. Had to replace 1 lower roller that I got for nothing more or less. An older gentlemen has a parts one and wants me to work on his after seeing mine so we "horsetraded" some things.
Post by mini kahuna » Tue Jun 15, 2010 7:27 pm
that is really great that your bringing back that machine,it deserves better than wasting away under a pile of leaves.
keep those pictures of your progress coming!!!!!! :D
Top Gun
Post by Top Gun » Tue Jun 15, 2010 7:29 pm
Rear wheels bead blasted, primed and painted in 1st coat of yellow.
Rear wheel guards done.
Blade bead blasted, primed in white epoxy primer, back side painted green.
Post by Lavoy » Tue Jun 15, 2010 7:34 pm
I have new upper idler shafts on hand, might have a used end cap as well.
You should have a couple more boxes of stuff showing up this week.
