Steering problems 350b
hdokes
Re: Steering problems 350b
Post by hdokes » Fri Aug 11, 2017 9:03 pm
The clutches are dry on mine as well. It is the later versions, C I think, that have the wet clutch and certainly the 450's.
My books, and I have the operators, service, and parts manuals don't seem to show anywhere what the diameter of the disc are and I'm getting conflicting reports from several different 'JD in the know' sources.
It would be great if Lavoy does have that sleeve. Still looking to hear on the parts status. I'll see if I can touch base with notmeu as you mentioned below.
Thanks dtools1
Leverage, it's what's for dinner! :idea:
60 Cat D6B dozer
?? JD 350b crawler/loader
02 JD 260 Skid Steer
68 Case 580CK diesel w/backhoe
67 Case 580CK Gas w/backhoe
81 JLG S35 scissor lift
Clark C500-70, C500-30, GCX40 forklifts
81 Intl 1854 dump
dtoots1
Post by dtoots1 » Sat Aug 12, 2017 6:56 am
hdokes,
need to find out just what the number of the tool/gauge is for your 350 steering.....i have the jd7 gauge which is used for my 440 steering clutches...i can certainly send it over to you once we find out if that what needed.....i also have made a pattern for the one for 2010 engine clutch but have not machined it down to specs as yet....
let me know....
thanks
dtoots1
Dennis
hdokes
Post by hdokes » Sat Aug 12, 2017 4:39 pm
So I just met a guy today in the town I am in who has a JD1010 crawler with blade. Needless to say we hit it off and could have talked all weekend. He had been through all this with his crawler when he bought it ages ago and began to show me some of the stuff he has. Dang if a LOT of stuff on the 1010 is interchangeable with the 350-b.... like... for instance... steering clutches..... go figure!. He's not part'n it out mind you.... he still uses it.
dtools1.... it turns out the jd7 gauge is the same one he uses for his 1010 which uses the same steering clutch and brake assembly as the 350-b. I'm beginning to think that is the same gauge to use on the 350-b. His gauge was a bit beat up beyond reuse. Also.... this guy used to communicate through this forum lots of years ago. I have no idea what name he used here as I didn't think to ask as I was conversing with him. As it turns out... he knows he has a complete clutch pack (brand new) in his arsenal but he has no idea where it is at this time. Hopefully he can find it before I take the plunge and purchase everything.
dtool1... just out of curiosity, do you attend the big engine show that goes on every year in Portland Indiana? It's coming up week after next. Lavoy... if you happen to catch this... this guy I met said he thought you attended the show as well in the past or perhaps someone representing jdcrawlers? Man if both of you go to this I'd like to meet up with ya.... it's in my back yard. For that matter... anyone in this forum that may be attending that show (biggest in the mid west) I'd like to meet up with ya. Maybe we could get a whole flock of JDCrawler owners together in one place... wouldn't that be a hoot!
60 Cat D6B dozer
81 Intl 1854 dump
dtoots1
Post by dtoots1 » Sat Aug 12, 2017 8:42 pm
hdokes,
well that may be opportune!!!!....am going to tennessee the 19th and will probably be coming back like the 22nd 23rd 24th and i see portland in is just a bit north out of Cincinnati, oh....so i may well be able to make a stop for day or so..believe it starts the 23rd???
look forward to meeting any of the jd crawler crowd and all other new folks..
dtoots1
hdokes
Post by hdokes » Sun Aug 13, 2017 9:01 am
dtools1,
I just put a new post/thread at viewtopic.php?f=4&t=11785 covering all the information about the show and the possibility of having a get together for all jdcrawler members who may be attending it. Hope it's the right place to have put it and everyone sees it.
Lavoy, let me know if it should go elsewhere.
60 Cat D6B dozer
81 Intl 1854 dump
Post by Lavoy » Mon Aug 14, 2017 8:29 am
Fibers are .175-.181, steel .090-.096. Pressure plate has to be adjusted once assembled to get correct finger height. I just got a bunch of gauges done, had been out of stock. Normally keep all the steering clutch parts on hand, on occasion do get sold out of one piece or another.
JWB Contracting
Post by JWB Contracting » Mon Aug 14, 2017 5:30 pm
Before we built out pin press, we removed a few pads (4 is best) and then lined the master pin up on the rear upward 10 or 2 oclock on the final drive and then cut a piece of pipe that just fits between the final drive housing and the master pin (large enough for the master pin to clear). We then used a pin driver with a 5 foot handle while the other guy hammered the pin out. We often would need to use a bit of heat.
We also use a large roller chain clamping device to keep the track links together if they are worn to line them up better. Its was a factory built unit that a local railroad company used to connect large roller chain. We now use this in combination with our press to give better line up on worn tracks and have ground the shoulders off slightly on many sizes of pins so we have very good line up before installing the master pins.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Mickey
Post by Mickey » Sun Sep 10, 2017 5:29 pm
The same thing just happened to mine had three minutes on the the clutch disc that I bought from eBay and they all break like glass.
Post by Lavoy » Mon Sep 11, 2017 9:35 am
And yet I get complaints that "I can buy fiber discs cheaper than you on Ebay" all the time. Yes, I have had defective discs like these in the past, many, many years ago. Guess what supplier I never bought another disc from and why. Not to mention that I warrantied the junk discs to the customer, ate the freight for the replacement parts both inbound and out and never got warranty from the supplier.
Post by Lavoy » Wed Sep 20, 2017 9:55 am
Called a supplier today and found out that the discs in the pic earlier in this thread are the same discs I mentioned earlier, and many times in the past. Seems they changed the dye in the discs so they are no longer black.
Users browsing this forum: Bing [Bot] and 28 guests
