I usually anti-seize the splines before I put it all back together.
40C popping out of gear
Took it all apart again. Raised the fingers are beyond the gauge. Seems to be better now but not perfect. If I have the ambition I will try to raise them another 1/8" just to see.
I try to limit my annual spend on this 'hobby' otherwise I would just go get a new clutch disc and pressure plate.
Just to clarify by the service bulletin the tab I should be using is the lowest one?
krusty wrote: Has to adjust the clutch fingers as they were high, but I would have expected low.
Clutch disc is in good shape. The plates has a slight oxidation to them in the pattern of the clutch disk for sitting so long I guess so I removed the oxide layer on the plate. That is the only thing I could see making it stick
Rust on anything in the clutch will make it drag.... OIL is even worse .....As for the fingers being higher that is to be expected as when the clutch disc wears the fingers get higher (not lower) and you lose free play /pedal The higher you make the fingers will get you more clearance on the disc BUT will limit your adjustment abilities later as you get wear... Also the higher the fingers the less pressure for apply from the springs .... I don't want to start an argument but if you don't have the clips still on the adjuster end of the fingers then you wont get any lift of the plate itself so it will try to drag
Thx for all of the tidbits everyone. It is all back together and steering nicely now. One brake band can use a bit more tweaking but for now will suffice.
I took the carb to a fellow with an ultrasonic cleaner last nite and put it back together this am and is runs nice too. an ultrasonic cleaner is on my list of valuable shop things
Will get a new clutch disk this fall when he winter comes and I am hibernating.
Did about 30 mins of dozing with it this eve and while it does not move fast at all it makes easy work of leveling out some piles. I hope to get several triaxles in this week of fill to spread around. Local road construction.
Users browsing this forum: No registered users and 266 guests
