whatchamacallit type electrical connector
cowboy4996
Post by cowboy4996 » Wed Feb 05, 2014 1:27 pm
You bet...always happy to help if I can. Once in a while 20 yrs at a JD dealership comes in handy....:)
lurch85
Post by lurch85 » Thu Feb 06, 2014 5:05 pm
well.. got the new harness piece from deere. exactly the same as what I just tried from napa. I must have some sort of replacement switch? there is a plastic ridge between the two "buttons" that wont allow the connector to slide on. Any ideas?
John Deere 420C, John Deere 350 straight with Gafner loader, John Deere 4020
Post by jtrichard » Thu Feb 06, 2014 7:04 pm
take the ridge out between the contacts ....are the buttons/pins the right spacing for the connector you have?
Post by Lavoy » Thu Feb 06, 2014 7:29 pm
Cut the wires and put on two female spade terminal connectors or something very similar that will go on the terminals.
Post by jtrichard » Thu Feb 06, 2014 7:53 pm
the connector is a packard 56 type they are made i a single version but may not fit side by side on your switch but you can get just the bare connectors http://www.pcsconnectors.com/2962965.aspx
Post by Lavoy » Thu Feb 06, 2014 8:36 pm
That's the ones I was thinking of, didn't know what they were called. I have put female spades on them in the past, and it will work, just probably not as good as the correct one.
Post by jtrichard » Thu Feb 06, 2014 9:00 pm
Lurch do you still have the original clip with the broken wires? if you do then you can just put new ends in it
