JD1010 Crawler Diesel Starter 9 or 10 tooth
gregjo1948
Post by gregjo1948 » Sat Nov 23, 2013 6:50 am
I had a 24 volt 1010 a couple years ago. Didn't start very well on 12 volts! :? I bought it from son of father that passed away. I don't think he knew it was 24 volt. I winched it on my trailer to get it home and proceeded to try to fire it up on 12 volt battery. Ended up removing the starter, thinking it was shot, finding the starter #'s revealing that it was indeed a 24 volt. Started right up with 2 12 volt batteries. Whoda guessed that? gregjo1948
DukeofDeere
Post by DukeofDeere » Sat Nov 23, 2013 7:07 am
No problem!
If you are looking for a rebuild shop let me know.
There is a local shop here that works on the old starters and generators.
Might be good to have it tested.
Could be time to replace cables and make sure the connections are good.
JT thanks for the comic relief!!
Duke
DukeofDeere
Post by DukeofDeere » Sat Nov 23, 2013 7:32 am
OK
My bad!!
Just reviewed my post and edited it.
The Diesel starter has 9 teeth! Not 10 as previously stated.
The gas starter has 10 teeth!
I will find my list of tag #s so there won't be confusion.
Duke
DukeofDeere
Post by DukeofDeere » Sat Nov 23, 2013 7:52 am
If a Delco Remy it would be a 1108672 tag # for the diesel 1010.
Duke
TunkCreek
Post by TunkCreek » Sun Nov 24, 2013 6:53 pm
Yep I forgot that little detail. mine is a diesel. Part # on the starter is 1107573 8 J 5; 10 tooth; another # on the gear housing is 1957960
I will email the pictures to your yahoo mail. Can't figure it out here. Thanks
Post by jtrichard » Sun Nov 24, 2013 8:29 pm
Yes it is a diesel starter from the pics you sent
