Two stroke diesel trouble
gregjo1948
two stroke diesel trouble
Post by gregjo1948 » Sun Jul 14, 2013 5:45 am
Could it be the valve adjustment/timing? On the 318 Detroit, the galloping was caused, I believe, by improper rack adjustment. gregjo1948
Post by jtrichard » Sun Jul 14, 2013 10:57 am
can you take the line loose from the pump and crank it with your thumb over the line see if you (A) get pressure (B) see if the fuel has air in it.... it could be you need to reseal the pump shaft ... I had that happen on 6v53 it ran like crap ... they don't like air
Post by Lavoy » Sun Jul 14, 2013 4:20 pm
That is what I was thinking, or pull the line off at the return and see what kind of flow you are getting.
ckutz1985
Post by ckutz1985 » Fri Aug 23, 2013 2:05 pm
It Was My Pump. I Just Rebuilt It And Everything Is Working Great Now. I Can Even Start Out In 5Th Gear And She Just Runs Like She Was new
Post by jtrichard » Fri Aug 23, 2013 3:44 pm
main seal is about all you can do with the pump is that what you did? on my 6V53 it was sucking air around the shaft at the seal and ran like crap i put new shaft seal in and she runs like new :D :D
diesel1
Post by diesel1 » Sun Sep 15, 2013 6:04 am
Did you work on anything else recently? All of the Detroits I worked on had a restricted fitting on the return line to maintain pressure between the pump and the injectors. Possible you took this fitting off and replaced it with a standard fitting?
Had a fuel problem with my old Pettibone/Dynahoe machine that was very similar to what you described. It would suck the filter dry and then shut down. Turned out to be a paint or rust flake in the tank outlet fitting. You might want to check again to make sure fuel is getting to the pump.
There's either a blockage somewhere or a suction leak. Gonna be something simple when you do find it.
Users browsing this forum: No registered users and 266 guests
