afi
- 40C crawler
Post
by afi » Fri Apr 05, 2013 6:03 pm
well i took dukes advice avice used a little. more starting flluid it chuged a couple times and spit out a lot of thick smoke then started riht up let it run a bit shut it off and it started fine. we'll see what happen tomorrow
Thanks Tony
DukeofDeere
Post
by DukeofDeere » Fri Apr 05, 2013 6:59 pm
Glad it is running!!
Add some Sea Foam to your fuel.
Wouldn't hurt to add some to the crankcase as well.
Clears out the carbon and frees up the rings in your pistons.
Duke
afi
- 40C crawler
Post
by afi » Sat Apr 06, 2013 3:24 am
well i took dukes advice and used more starting fluid, it chugged a couple times blew out alot of black smoke and then started. let it run a little shut it off and it started right up again. we'll see what happens today from a cold start
Thanks Tony
Post
by Tigerhaze » Mon Apr 08, 2013 10:42 am
I wouldn't use starting fluid on a 1010- too many bad things can happen. I've done it too but it is tempting fate.
Users browsing this forum: No registered users and 219 guests
