Good luck Brad.
You should take some pictures for those of us that haven't seen a reverser opened up.
If you don't want that reverser I might be interested. After pushing a little dirt for the first time I can definitely see the advantage of a reverser.
440ic engine clutch question?
whiteclipse16
- Crawlerbrad
- 420 crawler
Ben
I will try and post some pictures of the reverser as I am not sure either of what one looks like inside. It is all new to me. I am going to try to fix it because I can see that it is a big help when working with the machine. But if it cost to much to fix then I may have to reconsider. I will just have to see.
- DukeofDeere
- Crawlerbrad
- 420 crawler
- Crawlerbrad
- 420 crawler
Ok so I got down and dirty over the weekend. Got the reverser out and torn apart. What I found is that 2 of the 4 pins that hold the small gears in we're sheared off and the other were all chewed up. So looks like 4 new gears and 4 new pins to get the reverser back working. I am going to post some pictures if I can figure out how to. Thanks
[/img]
[/img]
Users browsing this forum: No registered users and 68 guests
