new to me 1010 diesel crawler basket case , 24 volt system
jdemaris
Re: 24 volt starter
Post by jdemaris » Wed Oct 17, 2012 9:43 am
ktheaker wrote:i can see im going to have problems with this , starter # is 1107559 . and i have not started but will be trying soon and i am going to assertain if . . .
If you get hunting for starters, here are some numbers:
2010 Gas engine 12 volt starters: Delco 1107879, 1107280, 1107326
2010 Diesel 12 volt starters: Delco 1107523, 1107556, 1107573, 1108672 Prestolite MFX-8001A
1010 Gas engine 12 volt starters: Delco 1107879, 1107280, 1107326, Prestolite MDY-8006A.
1010 Diesel engine 12 volt starters: 1107523, 1107556, 1107573, 1108672
1010 Diesel 12 volt starters: Prestolite MFX-8001A
1010 Diesel 24 volt starters: 1107547, 1108250
jdemaris
Re: Basket Case
Post by jdemaris » Wed Oct 17, 2012 9:48 am
woodsman wrote:Interesting subject. I recently built a battery box and mounted it right behind the seat, tied it to the under seat battery and with the two, it really cranks the 12 V starter over nicely. When I do a tear down and complete restoration this winter, I plan on changing over to an alternator and negative grounding system. I'm brand new to this site and will offer parts to any of you as I've accumulated 5-1010 dozers and 3-1010 loaders to part out. Had my original dozer since 1980 and have done just about everything to it but the complete restoration. Thanks for all your great information.
Martin
I'm assuming you' ve got the two 12 volt batteries in parallel and not series?
With later crawlers like the 350s and 450s - Deere offered diesels with one battery in warm areas and dual batterie in parallel in cold areas for better cold starting. At 0 degrees F, battery capacity is cut by 50% so . . . adding two batteries gives cold battery power equal to one battery in warm temps.
woodsman
Post by woodsman » Wed Oct 17, 2012 9:55 am
Oh Yea!! Parallel for sure. That's exactly the reason I did it as I use my dozer with the frame mounted arch in the winter pulling out firewood. Also for a point of information I put synthetic Amsteel Blue winch line on it. It has a higher working load rating than 1/2" steel cable and 100' only weighs 6-1/2 pounds.
ktheaker
24 volt
Post by ktheaker » Thu Oct 18, 2012 6:24 pm
thanks im going to need a team on this one - thanks for the advice - i will peak under the dash and see if i can see that 24 splitter , and i will advise my guy that i should switch the coil and fields , and the woods man and i - i think are going to be good friends by the time this is back runnng - thanks again
kt
ktheaker
24 volt
Post by ktheaker » Sun Oct 21, 2012 4:26 pm
its a tough spot to view with loader arms down and the machine not running to raise them any body have a 24 splitter that could be shown here or its exact location . i suspect this is a 12 volt system and somebody was trying to magiver a start on this unit . and yes wiring digram would be helpfull .
kt
Users browsing this forum: No registered users and 135 guests
