The pin boss is surrounding the pin, and as they rails and rollers wear, the rollers tend to hammer the bottom of the pin boss to a taper. I have had rails that have been run so far that it tapers so far up it wears the end of the pin to a taper as well. This makes it real difficult to install pins and bushings as I have no flat surface to push agains.
440IC in the trees
Not necessarily shot, just getting worn, depends on how thick the bottom of the rail is.
When this happens, unless the rail is really thin, the problem is shot bottom rollers.
In case that wasn't clear to you, it is simply wear on the roller faces at the hub where thinning of the roller results in more distance between the tip of the flange and the roller hub, allowing the contact.dnkcozmo wrote: I dont understand what causes this? all of the rollers turn and look good. what goes bad on the rollers that cause this problem??
- Paul Buhler
Follow up:
If you can get it for what you consider a reasonable price, consider the time, effort, and cost to get it home and cleaned up. I'll bet that its still hidden good qualities will make it worth the effort even if you decide to pass and re-sell it. The track rails look thick enough ~3", and if the center to center of five pins is closer to 23" than 231/2" you'll have an idea of pin and bushing wear. The bosses while tapered, don't look that bad to me, but as Lavoy said, indicated some flange wear on the rolls, some of which may need replacement. The sprockets and idlers look to have life left in them, and the track travel and sag shows some room for additional tightening if needed. A number of people here have been rebuilding 8a winches from worse looking ones than you have on this machine, so there is some equity there too.
Good luck making your decision. Paul
No, the rails on the 440 look pretty good yet, lots of depth to the link. If the pins and bushings are shot, now is the time to do it before the end of the pin tapers any more, then it gets to be a real problem.
I would bring the crawler home in a heartbeat.
lavoy
lavoy
Users browsing this forum: No registered users and 53 guests
