Track wear
mikeintn
Every undercarriage I have ever had has ended up looking a lot worse than yours. I have lots of roller wear but never a seized roller with the corresponding wear that would allow for chains to look like that. It looks more likely to me that your wear is somehow related to abrasion between the chains and rock guards. Not sure what would cause that in your case, for me it is side slopes of 50% plus chain twisting from climbing over stumps etc. along with normal roller wear. Are your chains and rollers "done", imho absolutely not.
PTO John
PTO John
John Watson
I have a neighbor that has a 450D and has put the small pinion gear out of his dozer several times he could never figure out why.So I went over and showed him the rollers were hitting the rails he installed new tracks and he still can't keep pinion gears in the machine any more just because he ran it too long with the rollers slamming the rails .It literally smashed the outer bearing races out of round in the pinion bearing holders .It's a nice old dozer but I know how little it takes to mess a good machine up and it isn't much .It really seem like the rollers are fine and the track is fine but they both are worn out This is what is called[ On Run Out ]in the industry .When you buy a Deere or any other crawler keep as much clearance between the roller flange and the boss head as possible .As was mentioned earlier there are a lot of contributing factors for track wear and this is just one of them bushings and sprocket wear is also one of the other contributors and most people only recognize the later .Digitup.
Users browsing this forum: No registered users and 294 guests
