JD 440 ICD rebuild (moving along)
Post by Paul Buhler » Tue Nov 22, 2011 1:34 pm
Hi: Fun to watch your rebuild.
In the past I've had problems with solid lines chafing against the frame from vibrations causing "hidden" annoying air or fluid leaks. To avoid this problem I made sure that the lines were fastened securely with isolation clamps or surrounded in a rubber hose to prevent this chafing.
Thought I'd share while you had things exposed. Good luck. Paul
Post by JD440ICD2006 » Tue Nov 22, 2011 1:49 pm
Paul,
My GM 2-53 runs smooth like a properly tuned John Deere Waterloo 2 popper that you can sit on 3 glass bottles. :lol:
Seriously, thank you for the advice, you likely saved me much retooling down the road. I will get some isolators and hide them in places that keep the lines safe but cannot be seen.
Post by Paul Buhler » Tue Nov 22, 2011 7:00 pm
Now you're bragging.
Careful work and attention to the details, like you've shown, seem to pay off. Congratulations. Paul
