Delco one-wire alternator conversion
bonker81
Post by bonker81 » Mon Apr 11, 2011 10:35 am
KenP wrote:Thanks for the update. If this works out, I'll probably give this swap a try on my 350.
Don't know much about GM Delco stuff but wondering if GM trucks might have a heavier v-belt and so a wider pulley.
If there's a local alternator rebuild place, you could give them a call and ask. They're probably know the answer right off the top of their head.
pictures if you do it Ken. I think the alternator on my 350 is on the way out so i would go this route also.
1970 350 with a 93A backhoe attachment
Mariner
Post by Mariner » Mon Apr 11, 2011 8:10 pm
I don't recall seeing it, but have you tried using a link belt instead of a rubber one? The link belts and great as they can be made different sizes and adjusted as needed - remove or add links.
marina
Hixon, BC, Canada
1968 JD450 Crawler Loader with ROPS, outside blade,rock guards, bucket and winch.
tjdub
Post by tjdub » Mon Apr 11, 2011 11:36 pm
Mariner wrote:I don't recall seeing it, but have you tried using a link belt instead of a rubber one? The link belts and great as they can be made different sizes and adjusted as needed - remove or add links.
I'm definitely thinking about it. I did a search on here for how to get the fan belt off and I saw them mentioned. It looks like I'll have to pull the hydraulic pump to change the belt out with a normal one? My 450 has the hydraulic pump disconnect thing on it, but unless I'm missing something, there's no way to slip a belt past that without taking the hyd pump out first.
If I go with the link belts, does anyone have opinions on brands or where to buy?
Les
Post by Les » Mon Aug 31, 2015 7:23 am
I know this thread is old, but I did the 1-wire alt conversion and got the new pulley. So, can anyone please tell me what size fan belt I need to get? The stock belt is too big now.
Les
1971 450B Crawler Dozer
Users browsing this forum: No registered users and 101 guests
