Help with Throw out bearing grease sert 350 1970 crawer.
KenP
Post by KenP » Wed Dec 29, 2010 11:40 am
deleted
dozingdozer
starter shot?
Post by dozingdozer » Wed Dec 29, 2010 12:43 pm
Thanks for the reply KenP. Checked all connections and battery but before I change out starter i'll clean all connections. Battery is fairly new and I put it on a trickle charge that brought it back to 100 percent in 5 minutes. had 14 volts at battery and on switchs and starter supply line but did not check the voltage at the starter under load. solenoid was kicking in but no rotation of starter. has been starting with no problems until this last cold spell. thanks.
76 JD 350 CE dozer-85 Vermeer 434 trencher w/bhoe
Users browsing this forum: No registered users and 257 guests
