- Site Admin
Post
by Lavoy » Sat May 21, 2005 9:10 pm
Used to be that the new ones were about $70, so who cares. But now when they are approaching $175, you just as well rebuild the one you have for a little more. Plus, if you are doing a complete resto, you can have them reset the hours to zero.
CCWKen
- 430 crawler
Post
by CCWKen » Mon May 30, 2005 11:12 pm
Speaking of tachs, does anyone have a picture of the dash of a 420C? I've got a tach, temp and amp but there's three smaller holes at the top. What are these for? Also, there's a "D" and "G" cast in above the choke. What is this?
A good picture of the dash sure would help.
JD420C, Ford 3910, IH 2606, Kenbota G32XKS
Jimmy in NC
Post
by Jimmy in NC » Sat Jun 04, 2005 9:26 am
If I'm not mistaken the holes are for key switch, fuse, and cigar lighter.
I have the wrong dash in our 420 so I'm not 100% sure. I 'll look at the books in the shop today and make sure.
Jimmy
- Site Admin
Post
by Lavoy » Sat Jun 04, 2005 12:03 pm
Center hole in top is for dash light, other two are for key switch, and cigarette lighter.
D stands for distallate, G stands for gas, it is where the fuel selector rod goes on an all-fuel.
Jimmy in NC
Post
by Jimmy in NC » Sat Jun 04, 2005 1:01 pm
Thanks for the correction there Lavoy.. I forget about the dash light since mine was toast and I now have it removed.
Jimmy
- Site Admin
Post
by Lavoy » Mon Jun 06, 2005 1:00 pm
Well I got the estimate back on rebuilding 3 tachs and one hour meter, are you ready for this, $1,860. YES that is a comma, not a decimal point. ONE THOUSAND, EIGHT HUNDRED SIXTY AMERICAN DOLLARS. In case you are wondering, NO I did not tell him to go ahead. Guess I will go to plan B.
CCWKen
- 430 crawler
Post
by CCWKen » Tue Jun 07, 2005 7:24 pm
Thanks for the dash layout info. Wasn't the keyswitch an option? If it was, did JD just put a plug in the hole? Also, does anyone know where to get a dash light? Original or Repro?
- Site Admin
Post
by Lavoy » Tue Jun 07, 2005 9:12 pm
Switch was an option, if you did not have it, then a plug goes in the hole. I have repro dash light for about $35, would need to double check, but should have one on hand.
BKahler
Post
by BKahler » Wed Jun 08, 2005 4:24 am
Did you remember to tell them you didn't need the gold plating option?!!
Brad
- Site Admin
Post
by Lavoy » Wed Jun 08, 2005 10:00 am
For that price, I was assuming that was gold plated, with diamonds on the indicator needle, and a ruby every hundered RPM on the face. I understand that nothing is free, but that is double what I know I can get it done for elsewhere.
/J^
- 40C crawler
Post
by /J^ » Sun Nov 20, 2005 4:41 pm
I had a tach worked on by a guy I take my starter and generators to. He pulled the glass of and cleaned the face of it and got it working again. He did a nice job shining it up without having to repaint it. He was also able to build a new cable for me and check it. I am thinking about laser cutting a template for the face of my tach to repaint the numbers on it. If any one is interested I can give you his number or send you a picture of the tach he did for me.
I also saw that someone asked about a Stewart Warner cable, I believe that was the original equipment manufacturer.
- Site Admin
Post
by Lavoy » Sun Nov 20, 2005 7:07 pm
Tach cables are no problem, I have new ones for about $25.
Users browsing this forum: No registered users and 43 guests
