John Deere 420c value
ONTARIO49JDMC
Post by ONTARIO49JDMC » Tue May 24, 2011 4:30 pm
gus wrote:
shinnery wrote:I believe the most common comment around here will be "Nice looking machine but the track is too tight."
:lol:
Yes, and look at how much adjustment remains!!! Must be near new. :shock:
I am not shure what you mean by too tight are the 5 rollers not to be like that i know i have seen some that look like they are too loose and the tracks have too much play in them.John
NOTHING RUNS LIKE A DEERE
JimAnderson
420c value
Post by JimAnderson » Tue May 24, 2011 7:58 pm
Hello,
The John Deere service manual calls for 7/8" to 1 1/8" sag
on the 5 roller.This measurement is taken by laying a straightedge
on top of the track and measuring to the top of the grouser midway
between the return roller and the drive sprocket.Tracks that are to tight
are hard on the finals and increase track wear.Tracks to loose aren't
good either.Luck JimAnderson
ONTARIO49JDMC
Post by ONTARIO49JDMC » Wed Jun 01, 2011 6:43 am
will having them like the one in the photo hurt the crawler or under carriage
stress it out or cause the tracks to loosen and have play or even break also how does the reverser in these crawlers work i am not shure on how this works.John
Post by Lavoy » Wed Jun 01, 2011 10:29 am
Tight tracks will greatly increase undercarriage and the potential for damage, along with increased drivetrain wear, and fuel consumption.
ONTARIO49JDMC
Post by ONTARIO49JDMC » Wed Jun 08, 2011 5:13 pm
how does the reverser work in these crawlers?.John
ONTARIO49JDMC
Post by ONTARIO49JDMC » Wed Jun 08, 2011 5:38 pm
also another queistion about the shifters in the 420 crawler i guess this would also be for the 320,330,420,430 seris tractor not just the crawlers i have seen two types of gear shifters on these series/crawler tractors one that is bent like 40 series/crawler and another that has shorter shifter leaver with the shift patern on the top of the nob with the same set up as most of the letter seires had was this an option with this or did they change over at some point.John
http://www.tractordata.com/photos/F000/56/56-td3t1.jpg
http://www.tractordata.com/farm-tractor ... ssion.html
Post by Lavoy » Wed Jun 08, 2011 9:21 pm
All are running changes that occurred over the years.
Users browsing this forum: No registered users and 218 guests
