Post
by JD440ICD2006 » Thu Nov 12, 2009 10:57 am
My bad, I had the DLTX confused as far as the shaft bushings.
The TSX only had a felt washer and a retainer.
I guess you could drill and press a brass bushing in there if it was worn bad enough.
But as Lavoy said, you should be able to correct any air leakage in that area with needle adjustments.
- Site Admin
Post
by Lavoy » Thu Nov 12, 2009 11:03 am
Normally the housing does not wear, and the shaft itself is what wears, usually a new shaft will tighten it back up.
Users browsing this forum: No registered users and 212 guests
