440ic slow to get moving
- john lewis
- 430 crawler
Seems like all i say is thanks, but thanks again i now have 25 and 26 lbs pull on revercer,but tractor no go.The revercer never worked before but at least i know it is going into gear now. I did compression test to see maybe it doesnt have power to move it, i got 110 on 1 and 120 on other, is that good or bad i dont know, they are close within 10 lbs fiqure not bad.When it was running and i shut her down she would diesel and then jump ahead now when i shut her down she still diesels but dont jump,so i figure it is not in gear .When i shifted it would make a lttle noise and not shift easy so i would lower gas go to different gear bring it back and it would go in easier.this is more info then i first started with, but im just reaching.Thanks again john
- john lewis
- 430 crawler
- john lewis
- 430 crawler
- john lewis
- 430 crawler
well its me again, before i pull the motor and start this does anybody know if i can get parts for clutch. From the parts manual it appears to be #am-379-t which shows up no longer available,from my understanding that is driven disk with facing that wear out.IF im not right about this can somebody let me know before i start pulling this apart thanks john
- john lewis
- 430 crawler
yes i checked free travel about 1 in .I was told that if u look into transmision tru filler hole and if there was no movement ,the main clutch was gone.I put tranny in gear and let out the clutch there was no movement that i could see,also i opened up access hole where u adj steering levers and there was no movement in there . so i guess i need to do clutch.U say lavoy has parts for 440ic clutch what is the plate that usually wears out called.Wondering if i should start another link when i start to replace clutch, im sure i will need help, thanks john
Sounds like you are right about the clutch being gone. The part is called the clutch disk. It is sandwiched between engine flywheel and a pressure plate. You also need to check these other 2 parts, not necessarily replace them, but check them for flatness and broken or weak springs or worn out fingers in the pressure plate.
It is also wise to replace the throwout bearing (behind pressure plate) and pilot bearing (center of flywheel), even if they look good.
- john lewis
- 430 crawler
- john lewis
- 430 crawler
Users browsing this forum: No registered users and 53 guests
