Cornhead Grease ?
Does Corn Head grease stay in the rollers and idlers ?
Poll ended at Wed Jun 04, 2008 1:03 pm
Yes
3
60%
No
0
No votes
Maybe
2
40%
Total votes: 5
jdemaris
Post by jdemaris » Wed May 28, 2008 8:10 am
Lu47Dan wrote:jd , Sounds like what we call "Open Gear Lube" up here will stick to anything :lol: and not flow away . :lol:
Thanks for the information .
I have the specs on the older Deere "Track and Roller" grease and also the current "Cornhead" grease.
Both are NLGI #00 - and there are many other companie selling their own versions. The older Deere "Track and Roller" was lithium-soap base. The newer "Cornhead" grease is polyurea based. From what I've read - all #00 greases are oil based with some sort of medium to hold the oil in place and keep it from leaking. The lithium works as well as the polyurea - but the later gives more protection from oxidation.
Fina in Texas - also sells a polyurea based #00 grease and it's the same green color as the Deere Cornhead grease. Maybe that's where Deere buys it from?
Deere Cornhead greasse current specs - Primarily for use as- cornhead grease but can also be used for many
other applications requiring NLGI #00 grease. AH80490/AN102562
Rated -30F to 330F. NLGI grade 00. Meets Deere specs. JDMJ13A5, J13E6, and J25A
Green color, Polyurea thickened. Dropping point 450 degrees F.
Penetration @ 77°F (25°C), 60 strokes - 355-385 mm/10
Water washout @ 175°F, loss - 10%
AN102562 - cartridge 14 ounces pack in boxes of 30
AH80490 - 35 lb. can
TY24428 - 120 lb. keg
Canada only - CXAN102562 is a 14 ounce cartridge, CXAH80490 is a 35 lb. can
Finalube Cornhead grease # 39590 - green color, Polyurea thickened, dropping point 460F,
base-oil viscosity at 40 degrees C - 150 Temp-range 20F - 275F
A few versions of #00 from other companies:
Chevron Texaco Dura-Lith NLGI 000 is a semifluid grease formulated to meet the lubrication
requirements of underground mining machinery having enclosed gear cases where housings and
seals have lost their ability to retain conventional gear oils.
Mobilith SHC 007 is an NLGI 00 Grade / ISO VG 460 grease with a synthetic base fluid; it
has a recommended operating temperature range of -50º C to 150 º C with appropriate
relubrication intervals. Its primary uses are in grease filled industrial gear cases subject to high
temperatures, where conventional semi fluid greases will not provide acceptable lubricant life
and in non-driven heavy-duty truck trailer wheel hubs.
vics - 460 at 40C
Castrol SHL 00 is a synthetic, semi–fluid NLGI 00 grease that combines the stay–put power of
a grease with the consistency of a gear lubricant. As a result, Castrol SHL 00 virtually eliminates
fluid leakage from wheel seals, hubs and axles, which can be a serious environmental and safety
hazard for over–the–road fleets and can increase maintenance costs. Castrol SHL 00's synthetic
base stock gives it excellent low temperature mobility and high temperature stability. NLGI 00
lubricants are recommended by The Maintenance Council in their Recommended Procedures
for Wheel End Lubrication (RP 631). Castrol SHL 00 can also be used in quarry, industrial,
mining and construction applications where a semi–fluid grease is recommended.
AMSOIL Spy Grease Synthetic Lithium Complex 00 EP Grease
Synthetic Lithium Complex 00 EP Spy Grease (GSF) NLGI #00
pour-point -37F, visc - 414-500 at 40C, 28-35 at 100C.
Service range temps -29F to 177F. lithium complex semifluid grease
Post by Stan Disbrow » Wed May 28, 2008 9:02 am
Mmmmm. Applesauce. Molassas. This thread is sounding mighty tasty! ;)
Don't forget other tasty descriptions, like Butter and Jam for the thick stuff! :P That tongue there is me licking my lips, BTW!
What do we call that thin engine oil most new cars and trucks are using, the 5W stuff? Apple Juice?? That'd go well with the Applesauce in the track rollers! Mmmmm. :)
Later!
jdemaris
Post by jdemaris » Wed May 28, 2008 11:57 am
Stan Disbrow wrote:Hi,
Here is more food direct from the NLGI tables. This is how the NLGI describes the different grades of grease - but it's not done with gear-oils. That because NLGI ratings apply to grease pumpability. Usually rated at 60 stroked at 25 degrees C.
NLGI grade # - pumping classification at 60 strokes - appearance - food analogy
NLGI # 000 445-475 fluid cooking oil
NLGI # 00 400-430 fluid applesauce
NLGI # 0 355-385 very soft brown mustard
NLGI # 1 310-340 soft tomato paste
NLGI # 2 265-295 moderately soft peanut butter
NLGI # 3 220-250 semi-fluid vegetable shortening
NLGI # 4 175-205 semi-hard frozen yogurt
NLGI # 5 130-160 hard smooth pate
NLGI # 6 85-115 very hard cheddar cheese spread
teighs
Post by teighs » Mon Jun 02, 2008 5:58 am
My green Deere dealer has NGLI 0 and NGLI 1 cornhead grease. My 350 manual calls for NGLI 0 grease in the rollers.
Post by digitup2 » Mon Jun 02, 2008 7:43 pm
Deere needs something for the new machines that will stay longer I have had several machines rollers leak through the seals with less than 100 hours the first ones went If you look at the photo of my 450J that was two years ago .It was leaking on the second roller back as we ran it It had less than 50 hours on it on the new roller seals they just don't last even new that day and they don't last .Warm weather is a good test of roller seals for some reason I don't realy want to start shoveing corn head grease into a machine thats new but it turned two yesterday and the waranty was gone off it yesterday also with 2448 Hours on the meter next roller to leak gets grease!!Digitup.
tuney443
Post by tuney443 » Sat Jun 21, 2008 3:28 pm
You guys won't believe this but today I actually used up my last cartridge of official dirty yellow JD track and roller grease from my old 350B days--about 31 years ago.Funny weird thing,the unopened last 2 tubes were only half full--very strange--where did it go? Or did the loading mechanism malfunction 31-33 years ago? More money for Deere---Hmmm.Glad I still kept my greae button adapter also--probably hard to find and pricey.
Found the skull to the mastodon in Hyde Park, youngest one ever found so far in the world in 2000.
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
tuney443
Post by tuney443 » Tue Jun 24, 2008 6:38 am
Here's the specs from Schaeffer Oil on 0 or 00 grease. For those that never heard of Schaeffer,they have outstanding products,are known as the oil company who truly perfected soluble moly in oils without separation. Oldest oil co. in the U.S. The 0 grease would be their #274,towards the bottom--I use that but in a#2 weight---I'm going to call my Schaeffer rep today,I'm hoping I can buy less than a case of 30 tubes of the 0.
'' With a reputation for lasting two to three times longer than the competition, Schaeffer greases come in numerous formulations to meet the needs of a wide variety of applications. ''
Type
Product Product
Type Temperature Range Base Dropping Point Application
Moly Multi-purpose Bearing Grease #221 Moly Ultra
NLGI #1
NLGI #2
0° to 350°
20° to 350°
Aluminum Complex 500°F Multipurpose, extreme pressure grease for hot and wet applications.
Steel industry, mining and extreme duty formulation.
Extra MoS2
#238 Ultra Supreme NLGI #1
NLGI #2
NLGI #3
-10° to 350°
0° to 350°
30° to 350°
Aluminum Complex 500°F An upgrade version of #221 with extra tackifier, extra solid lubricants and synthetic blend base.
Steel industry, mining and construction equipment.
Extra MoS2
#229 Ultra Red Supreme NLGI #1
NLGI #2
-10° to 350°
20° to 350°
Aluminum Complex 500°F Semi-Synthetic
Red Color
Synthetic Moly
Teflon
High Temperature Moly Bearing Grease #248 Moly Syngard 2000 NLGI #1
NLGI #2
NLGI #3
-15° to 600°
0° to 600°
30° to 600°
Bentone None Versatile, multipurpose, tacky, extreme pressure and heavy-duty hot applications.
Intermittent to 600° F.
No dropping point.
Synthesized moly.
#260
Perma Moly NLGI #1
NLGI #2
NLGI #3
-10° to 600°
0° to 600°
30° to 600°
No dropping point.
MoS2 & synthesized moly.
Synthetic Grease #197 Moly Pure Synthetic Grease NLGI #2
30° to 600°
Bentone Bentone Multipurpose, extreme pressure and wide temperature range.
Intermittent to 750°.
MoS2
Synthetic Blend Grease #274 Moly
E.P. Synthetic Plus Grease NLGI #0
NLGI #1
NLGI #2
-50° to 350°
-30° to 350°
-20° to 350°
Aluminum Complex 500°F Use one grease Summer and Winter.
Synthetic blend base eliminates changing grades.
Versatile, multipurpose, extreme pressure.
Steel industry, mining and construction eqiupment.
MoS2
Extreme Temperature Compound
Type Product Product
Extreme Temperature Compound #286C High Temperature Grease with Copper 1120C
600° to 1200°
Silica >500°F With copper
Specially made for hi-temp applications that destroy
Silica gel thickener evaporates cleanly leaving lubricating solids behind to prevent wear and gelling
For mine and mill use, kiln car wheels, etc.
#286 High Temperature Grease
1120
600° to 900°
Silica >500°F Same as 286C except without copper.
Specialty Greases
#195 Supertac Food Grade Grease H-1
H-1 and USDA listed. Our most waterproof food grade grease for heats to over 350 °F.
#271 Synthetic Food Grade Grease H-1
Synthetic grease formulated for the lubrication of ball, roller, journal, and sliding bearing applications features high temperature resistance and our special Microshield® that fights bacteria growth.
Schaeffer Manufacturing Co. 102 Barton St. St. Louis, MO 63104 Tel: (314)865-4100 Toll Free: (800) 325-9962
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
Post by Ray III » Sat Jun 28, 2008 6:14 am
That's very interesting the diversity of greases. We're getting a new induction furnace in our foundry sometime and I'm interested to see what sort of grease and hydraulic fluid will be specified.
Also building a slag cart for our current cupola furnace, not sure if I should even bother greasing the wheels.
