Success!!! The bolts are out.
I had another go at it today. I bent a torch tip to get access, heatted the bolt pice as best I could and then tapped on it with a rod.
Then I went slow and easy with the drill followed by the easy out.
Broke one drill bit off but I was able to extract it becouse it broke where I had welded the extension on.
Now, off to get some new bolts.
The bolt that came out has a unique shoulder. I'm wondering if I should go to JD and get the same bolt or just replace it with a standard grade 8 bolt.
Thanks for all the luck and advice.
Special thanks to Digitup for the email suggesting the Molson. I'm sure that's what got it out.
Dan
450 frame to bell housing bolts
Users browsing this forum: No registered users and 66 guests
