1952 MC crawler
fundytides
Re: 1952 MC crawler
My 40c starter will jam once in a while. I find that if I loosen the nut and tapered bolt that locks the starter in place and then pry the starter away from the flywheel a bit, the bendix will usually come free. Shove the starter back in place, install and tighten the bolt and lock nut and away it goes. Good luck!
roadbuilder
Re: 1952 MC crawler
Thanks Lavoy,
Still doing hay, and haven't pulled the starter yet.
My friend thats is interested in it has offered to come down and help "tinker" with it.
Just so I know going in....How much for a starter? And I expect also a switch?
roadbuilder
Re: 1952 MC crawler
Thank you Fundytides!fundytides wrote: ↑Mon Jun 16, 2025 8:09 pmMy 40c starter will jam once in a while. I find that if I loosen the nut and tapered bolt that locks the starter in place and then pry the starter away from the flywheel a bit, the bendix will usually come free. Shove the starter back in place, install and tighten the bolt and lock nut and away it goes. Good luck!
Re: 1952 MC crawler
Starter is $400 + freight, switch is already installed.
roadbuilder
Re: 1952 MC crawler
Thanks Lavoy,
How about an ignition switch?
Re: 1952 MC crawler
Sorry, misunderstood, thought you meant the switch on the starter.
Ignition switch is $40, no lever.
