Track and turning issues
Re: Track and turning issues
Post by Lavoy » Wed Aug 07, 2024 8:12 am
Best way to get a stuck track adjuster apart is just pump the piston all the way out of the barrel with a grease gun.
Post by Stan Disbrow » Wed Aug 07, 2024 10:14 am
This sounds like one of those crawlers where you take it all apart until you have just the transmission left. Then: check, clean, repair and replace all the bits in there until it is right. Then: start bolting the rest of the machine to the trans, doing the same on each thing, until you have a reassembled crawler where all works as it should.
It's not a job for the faint of heart.....
Eli
Post by Eli » Thu Aug 08, 2024 11:38 am
I did try to pump the grease with 4 front bolt loose and I have no movement at all, do I need to buy a powered grease gun?
I have room at the front for it to slide, should I remove the bolt and see if it tries to retract at all?
Can it be repaired if frozen or junk at that point?
Thanks.
Eli
Post by Eli » Thu Aug 08, 2024 11:54 am
Members have replied on my track post so I will discuss it further over there.
As far as complete disassembly of the whole machine it's not possible for me now, I don't have the place for it, I have a carport for it now but high winds and sand and rain, not going to attempt it for now until I'm able to get a shop or garage.
I'm doing piece by piece, it has a full size MF backhoe "home made" that paid for itself already.
