40C not turning to the left - fiber clutch thickness
dtoots1
Re: 40C not turning to the left - fiber clutch thickness
Post by dtoots1 » Fri Jul 05, 2024 3:14 pm
Well Pauly,
Sure am glad you found the problem and solved it..
Now i dont recall you specifying if this was dozer or loader....so am asking...which is it? and if is Loader...what hydraulic pump is it?? cam pump or crank pump..if crank pump is it Hydreco? Being a 40c suspect you have cam pump?
pauly68
Post by pauly68 » Fri Jul 05, 2024 5:11 pm
It’s a dozer-has a blade on it. It does have the cam driven pump on it. It’s all 40C but the hydraulics. Tractor is a 1955 but the blade was added in 1958 so it has a 420C valve stack and reservoir on it but has the 40C hydraulic pump on it.
1955 JD40C with 420C hydraulics and 6' Leeman-Hass blade
1965 JD 1010 RS High Cropper
