Jd 40c good price or not?
JimAnderson
Re: Jd 40c good price or not?
Post by JimAnderson » Sat Feb 10, 2018 8:23 pm
As per the previous post the 440 has 36 track links.With that much adjustment left I would definitely count links.If you end up with 35 then the machine has been short tracked.This is not uncommon and just means you will be dumping money into pins and bushings plus labor.The missing links will need to be found or replaced.If you intend to work one of the two machines the 440 is much more capable.Count on spending lots of time and or
money on any 50 year old crawler.Luck,JimAnderson
4 430C crawlers
1 40c 3 rollers
1 420c 5 roller
1 440c loader
1 430t tractors
1 IH H
1 3020 JDs
I Ford 3400 loaders
2 IH Cubs
6 WH GardenTractors
hydrogeo
Post by hydrogeo » Sun Feb 11, 2018 7:39 am
The winch on the 440 is a huuuuge plus. I use the winch on my 40c almost as much as I use the blade, between cutting wood, dragging "collectables" around the yard, etc, it's really handy.
Post by Lavoy » Sun Feb 11, 2018 5:05 pm
A "good" cherry picker will be just fine, assuming you are on concrete. That is all I had for many, many years til I got a forklift.
I would lean towards the 440 for a using crawler.
Timr82
Post by Timr82 » Thu Mar 01, 2018 8:42 pm
here are some images of the 440 under carriage opinions on the condition is greatly appreciated. http://i1042.photobucket.com/albums/b42 ... y7mau.jpeg
http://i1042.photobucket.com/albums/b42 ... hgvb5.jpeg
http://i1042.photobucket.com/albums/b42 ... vzcdn.jpeg
in had more but having issues loading and bringing them back up but their are 36 pads on each side.
Timr82
Post by Timr82 » Thu Mar 01, 2018 8:46 pm
I can email pics of the sprockets but couldn't load them do to computer issues or issues with photobucket. It would show it in library but when clicked on to get link would say it was moved or deleted.
dtoots1
Post by dtoots1 » Fri Mar 02, 2018 8:11 am
Timr,
have you tried to use our own "pic server" that is dedicated to this site??? Send a pm msg to Lavoy with your login and password for the pic server that you wish to use.. If you need help getting started advise and we can walk you through it.
Everyone on here have tended to get away from Photobucket because of loss of all the pics that had been on it for free and when they wanted to charge for the service they deleted those that wouldn't pay for the service.
access to the portal is in the Q&A forum at the bottom of the "Board index".
dtoots1
amos
Post by amos » Fri Mar 02, 2018 8:33 am
track rails look good but rollers not so much. Not too much to go on but it appears the grousers(pads) and rails(chain) are OK so repair could be only to rollers maybe? About $100.00 each but big job to replace. You will probably find some broken bolts and surely find some seized bolts.
Jack up one side,pull track group,then pull the entire assembly as it's easiest to flip it upside down to get to bottom rollers and mounting bolts.You're probably looking at 40+ hours per side unless you are set up to do it as a shop would.
If sprocket and front idler are as bad as rollers those will need to be replaced and also good time to rebuild or replace track tensioners.
Amos
