Ripper shanks 350C wanted
http://i61.photobucket.com/albums/h53/G ... snhjgm.jpgjtrichard wrote:More pics of both the ripper and front bucket ....Any tags???
JD 455E 1988
https://i.ebayimg.com/00/s/ODUyWDExMzY= ... c/$_20.JPG
Appears to be the same ripper as whats fitted to my 350.
Re: JD 455E 1988
https://i.ebayimg.com/00/s/ODUyWDExMzY= ... b/$_20.JPGgtb wrote:https://i.ebayimg.com/00/s/ODUyWDExMzY= ... c/$_20.JPG
Yes its for sale in Australia. The Bucket on my 350 is made in Australian (8 meter cube)jtrichard wrote:IS that 455 down under also? probably is made there then
Found this web sitehttps://www.yumpu.com/en/document/view/11477892 ... ompany/139
I was told I should get shanks laser cut and weld boots/teeth
cheers
Graeme
The link above works if you delete "site" off the front of the link.
Re: Ripper shanks 350C wanted
https://www.hltooth.com/wp-content/uplo ... rifier.pdf
Still looking for shanks purchased a T149204 off a JD607B/JD670CH Grader is a close fit. I will look at having some made.
Thanks for all your help.
Cheers
Cheers
