JD350 Loader keeps dying HELP!!
- Paul Buhler
Did you blow out the feed line a second time? I suspect that your tank has more gunk still in it and needs further cleaning. I'd check that the lines and filters back from your injection pump to the tank are clean and use a temporary milk jug fuel tank to see if the dozer runs as it should- plug the bottom of the machines metal tank so it will hold the returned fuel. I have often had machine problems that turned out to be an easier and less costly fix than first thought.Amazing how we almost always expect the worst, then with some more digging,find a gremlin lurking and laughing. Hope you only have a dirty fuel system. Good luck. Paul
