crawler 40 alternator
Post by Stan Disbrow » Thu Dec 17, 2015 6:26 am
They were painted both ways. Green for ag, yellow for industrial. No real difference when it comes to the machine. Usually owners repaint them, but sometimes, they yanked bits across the factory and repainted on the fly.
For example, my 420c is green all the way, except the reverser which is yellow under green. I know it was ordered Ag because my uncle sold it new, then got it back 10 years later.
So, now you get to check all your main castings to see if they are green under yellow or not. :P
Oh, and the track frames were all yellow, as were the sprockets and idlers. So don't bother looking there. ;)
kevencyr
Post by kevencyr » Thu Dec 17, 2015 8:01 am
ok, good, so basically, if i can't make my mind. i probably go yellow. for some reason i like the yellow. thanks
Post by Lavoy » Thu Dec 17, 2015 5:30 pm
Keep in mind if you go hyd, you will need an auxiliary hyd system consisting of a larger pump, reservoir and valve. OEM hyd will run about a 1,000 winch very, very slowly.
kevencyr
Post by kevencyr » Thu Dec 17, 2015 6:35 pm
this is getting complicated, might let go my winch idea. :D
Post by Stan Disbrow » Fri Dec 18, 2015 6:32 am
There is always the option of hanging a big hyd pump on the PTO. But, if it were me, I would put a PTO driven winch on the back....
Post by Lavoy » Fri Dec 18, 2015 9:27 am
You need a PTO driven winch, really the only thing that will work well and survive long term.
kevencyr
Post by kevencyr » Fri Dec 18, 2015 10:00 am
I've been looking for one and when i got one, they want over a 1000$ without knowing if they run and if they are in good shape inside, i seen some picture from a guy on this forum, you could see see some crack on the inside part that you could not see outside. i'm talking about that gearomatic model 8 type
Users browsing this forum: No registered users and 414 guests
