JD 440ICD
jac
JD 440ICD
Post by jac » Mon Sep 12, 2005 11:46 am
Just purchased a JD440ICD. Can not start the machine but previous owner said it ran 3 weeks ago. Starter will engage but engine will not turn over. I have several questions
1) Is this a positive or negative ground system?
2) Is there a compression release to make starting easier?
3) 12V starting circuit?
Post by Lavoy » Mon Sep 12, 2005 12:16 pm
Check your batery cables, but it sounds like the solenoid died.
Positive ground 12 voly system, no compression release.
jac
JD 440ICD
Post by jac » Mon Sep 12, 2005 12:32 pm
Lavoy; Thanks. I had it wired as a negative ground. Will reverse and see what happens
jac
Post by jac » Mon Sep 12, 2005 5:22 pm
Lavoy: thanks for the advice. Got the machine started. Engine was a little stuck, but with a little help and two batteries, it finally started. Everything seems works except the steering, so I guess I will have to learn how to repair the steering clutches. I read somewhere that there is a CD repair manual. Do you know how to purchase the CD? How involved is the steering clutch repair?
Post by Lavoy » Mon Sep 12, 2005 6:43 pm
Search through the message board, somewhere in there is the contact info for the gentleman that is making the CD manuals.
Steering clutch work on a 440 is not easy, more so on a loader crawler. Get the parts and service manual before you start.
jac
Post by jac » Mon Sep 12, 2005 8:18 pm
Lavoy: Found the gentlemen with the CD manuals on your site. Thanks. Opened the clutch covers and the left steering mechanism is moving freely, but rusted. Right side linkage is pretty rusted and seized. Gaskets were gone on covers so everything appears to have gotten wet over time and rusted. Carefully applied small amount of penetrating oil to linkages but my guess is the pressure plates are also rusted and not disengaging. Brakes seem to work but will stall engine if apply too hard.
I have a crawler loader so sounds like this will be challenging!
Jimmy in NC
Post by Jimmy in NC » Mon Sep 12, 2005 8:31 pm
jac-
Have patience and take your time. In the end it will be worth it. Just don't get yourself in a bind as parts can be heavy!
Jimmy in NC
BKahler
Post by BKahler » Tue Sep 13, 2005 4:57 am
jac wrote:Lavoy: Found the gentlemen with the CD manuals on your site. Thanks. Opened the clutch covers and the left steering mechanism is moving freely, but rusted. Right side linkage is pretty rusted and seized. Gaskets were gone on covers so everything appears to have gotten wet over time and rusted. Carefully applied small amount of penetrating oil to linkages but my guess is the pressure plates are also rusted and not disengaging. Brakes seem to work but will stall engine if apply too hard.
jac,
After reading your post I sent you a private message about the CD. Let me know if you're interested.
Brad
jac
JD 440ICD
Post by jac » Tue Sep 13, 2005 5:59 am
Thanks for the information. How much of the rear end of this machine needs to be deassembled to get to the steering clutches? No obvious easy access, so I am guessing this requires quite a bit of diassembly. I plan on ordering the CD manuals which hopefully will make this a little easier. Should have no problems with the weight of the parts since I have a 1 ton gantry, which should be enough for the various part removal. Just need to get the crawler under the gantry!
Users browsing this forum: No registered users and 318 guests
