I'm looking for the hydraulic cylinders that lay horizontally in the middle of the tracks and run the blade on a JD40.
Thanks,
Looking for JD40 hydraulic cylinders
Tim Wells
Dayton OH
(937) 848-6547
Dayton OH
(937) 848-6547
I have a little more information. The part number for the cylinder assembly, which only includes the cylinder housing and the two bushings for the lifting arm are:
AN2417YC for the left cylinder
AN2418YC for the right cylinder
The JD40 is a 5 roller.
Thanks for your help,
Tim Wells
Dayton OH
(937) 848-6547
Dayton OH
(937) 848-6547
Tim,
If your housing is cracked, it is likely everything inside is OK, so all you would need is the empty case. I do not have any right here, so can't check immediately. I believe I have some at the farm, would have to check. If you want, send me an e-mail and when I get out there, I can get back to you. I would guess a few weeks before I have time to go out there.
Thanks,
Thanks,
Users browsing this forum: No registered users and 150 guests
