John Deere 1010 crawler trying to figure out year
Hi, thanks for the add! I have a 1010 crawler. I am not sure of the year or what the serial number would be, I am looking on getting some help trying to figure out what it could possibly be? The left side final drive locked up on me so I am trying to find a rebuild barring kit for it
Re: John Deere 1010 crawler trying to figure out year
Welcome to the boards
The serial number tag should be on the right side of the engine block.
For parts call Lavoy Wilcox, the provider of this website. His business is repair and parts for vintage JD crawlers. He can help you with parts and manuals if needed, as well as technical information. His phone number is 701-361-1006 during CST business hours or email him: postmaster@jdcrawlers,com
Thanks for the quick reply,sorry I forgot to mention that the serial number tag is missing
I had the same problem - no tags. The best I could do was narrow down the serial number range by some of the design differences. For example, shifter moved from dash to floor at s/n 21900, Hydraulic control levers moved to a box on RH Fender at 31000 & Reverser oil filter cover plate changed from 1 piece to 2 at 42000. Check the parts manual for details. Once you have the serial number narrowed down to a range, you can make a best guess for year.
1963 (?) Deere 1010 Crawler-Dozer
1955 Ford 850
1973 MF40 Ind
1955 Ford 850
1973 MF40 Ind
Users browsing this forum: No registered users and 37 guests
