motor identification
I saw and add on market place, JD 3cyl engine $350. Skeptical but went to look at it and it had everything complete radiator, starter, inj pump, alt. and still attached to reverser. sitting in the grass but guy said it was running good when he removed it. For the money it was worth it for the external parts. when I checked it it won't make a full revolution, get about 340 degrees either cw or ccw. can be a few different things but hoping is a valve stuck open contacting a piston. Don't really care. Can anybody tell me if infact it's for a 350 and what year. I have machine serial numbers charts but not engine. Number on it is SNM43TE013095 T little plate bottom of block near oil pan.
Also my manual tells me the machine weight for a 350 but not individual components, Anybody know what this engine coupled with the reverser might weigh? I have to take it off my truck tomorrow with my medium size skidsteer and wondering if it will handle it or if I have to split them? Machine should handle 2,000 lb alright.
67 JD 350
Re: motor identification
Below is the breakdown of the early engine serial numbers from an early 350 service manual. it is a 3-cylinder diesel that was originally in a 350 crawler loader. I don't know of any way to tell the year without going back to John Deere. The serial number format indicates it is an early 3-152 diesel engine (1965-1966).
I don't know the weight, but I think you will be able to unload it with your skid steer. As with any load don't pick any higher than needed, keep it close to, the ground once clear of the truck and when travelling. If you have a quick attach and can reach it without a bucket on, the closer to the end of the boom arms you can hitch the better.
Thanks Jim, that helps a lot. Have not been around these for long but at a glance I was pretty sure that was a 350 motor and reverser.
I did see on the broken tractor parts site they list this engine for sale as a long block with a shipping weight of 400 lbs.
When I picked it up the guy loading it was inexperienced with his bobcat 853 which is a sizable skid, he refused to load it into the middle of my flatbed because he thouht his machine would not handle it that far out from his machine so it ended up on the very end of my bed. The whole experience was just weird and frustrating but what can you do.
Seeing 400 lb on motor makes me think no problem, even if that reverser is over 1000 and I dont think it is.
Guy was just nervous I guess.
67 JD 350
Your combined weight will be less than a 1000 pounds. I'm guessing around 700 to maybe 800 pounds. I easily handled a 350 engine with my little 1025R compact tractor.
Once I got it on the hook I almost had to laugh , the New Holland skidsteer handled it easy, the guy loading it had a huge Bobcat and said he was afraid it eould tip had me thinking this thing was over a ton, the reverser does look heavy I guess.
Anyway tore exhaust manifold off and held the valves open while blowing compressed air through ports and a ton of crap came out of exhaust and intake. Motor now turns free , still may pull head for thorough cleaning. Compression seems good and under valve cover was clean.
67 JD 350
If I pull the head for cleaning snd a little R&R do I need new head bolts to reinstall, dont know if these are a stretch bolt design?
67 JD 350
As long as they look good, they can be re-used. They are not torqued to yield bolts. Clean them well, wire brush the threads and inspect them carefully. Lightly oil them before installation. The holes in the block should be cleaned and be chased with a bottoming tap (blow out when finished).
When you remove the head use some short cap screws with washers in the head bolt holes to clamp the cylinder liners down, otherwise the liners could pop up when the engine is turned over.
Your Service Manual engine section should cover most of this.
Good thought Jim on clamping the liners down.
this thing now turns freely, pulled manifold and mufler got a lot of small acorns or some kind of round nuts and a mouse nest out of it. Not sure if it was in the mufler or I back blew it out of a cylinder into the muffler with compressed air.
So do I take the head off or attempt firing it up?
67 JD 350
stick a propane torch in there and burn up the mouse left-overs. then blow it out again, probably be good to go.
Users browsing this forum: No registered users and 34 guests
