450c John Deere crawler
For some reason the fill plug on steering clutch housing on both sides is over filling and I know I have never over filled it. Does anyone know what else could cause it to overfill?
Re: 450c John Deere crawler
450C should have the common sump. The steering clutch housing plugs are commonly installed with Loctite to prevent opening them. The common sump level is a bit higher than the level used when they kept the compartments separate. Check and fill location for those compartments is the transmission. During a full service they can be removed, fill to the plug level, install the plugs and check/top off the transmission. Check several times a while apart to let the levels equalize.
There should be info in your Operator's and technical manuals about this.
Users browsing this forum: No registered users and 31 guests
