JD 350B Final Drive Removal
Jamie Dunn
Post by Jamie Dunn » Thu Jul 03, 2025 5:39 pm
I have removed every bolt and loosened the brake band. I cannot get the final drive to brake loose from the transmission. Any help?
jimmydiesel
Re: JD 350B Final Drive Removal
Post by jimmydiesel » Fri Jul 04, 2025 3:28 pm
Did you remove the 2 bolts on the backside that go thru the steering clutch housing?
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
Jamie Dunn
Post by Jamie Dunn » Fri Jul 04, 2025 9:17 pm
yep. Going to try a jack between the 2 final drive cases.
Jamie Dunn
Post by Jamie Dunn » Tue Jul 08, 2025 1:04 pm
I got the final drive out and apart! Went well. Now I need a new (used) flanged axle. I got one but the splines are much more course. This is for a JD 350B. Any ideas where I can find one?
Jamie Dunn
Post by Jamie Dunn » Tue Jul 08, 2025 3:05 pm
I have been looking up parts for a JD 350B as marked on machine. The Serial # 350CE 328147T. Is it a 350C or 350B? I ordered a used flanged axle shaft and the one shiped has 20 splines and the one in the dozed has 43 splines.
LeonardL
Post by LeonardL » Tue Jul 08, 2025 6:53 pm
If your serial number is true to the machine then you have a 350C. If your final drive that you removed had oil in it before you removed it, then it is a wet clutch machine which will also indicate it being a 350C and not a 350B. A 350B will have dry steering clutches and no oil inside the housing.
Users browsing this forum: Google Adsense [Bot] and 191 guests
