1010 diesel crawler loader water pump part # at13878
anyone know where I can buy a water pump for my 1010 diesel crawler part # at 13878?
Re: 1010 diesel crawler loader water pump part # at13878
Crawler pumps are R & R only, there are no new ones that I have ever found.
any thoughts on where I could buy a good second hand water pump? Has to fit Diesel 1010 crawler part # at13878
When you asked about this the other day you said it was sold to you as a 1964. A 1964 would be in the higher serial number range and should use the AT14998 water pump by the parts catalog. The 10001 through 21900 serial numbers cover 1961- mid 1962 according to the serial numbers listed for the 1010C on the FAQ Board here. Do you have your serial number?
I see you are in Rhode Island. You might check out AG Rebuilders (formerly Arthur Gould rebuilders) located in Rutland, MA. We have gotten a couple water pumps for equipment from them that the other part sources could not help with. They specialize in rebuilding water pumps. Worst case you might have to send your pump to them and have it rebuilt. Here is a link to their website, check it out.
AG Rebuilders
AG Rebuilders
thanks for the help !
Users browsing this forum: Google Adsense [Bot] and 38 guests
